My ATV2 with aTVflash black has been brilliant.
Not used it for a while and I though would use it properly. Did an update and brought everything in line. I opted for iTunes Match and did a mega update on my library over the last weekend.
Issue that I have is that I play 1 track from an album and then it will skip through the rest. The next track I manually select then gives the “iTunes is unavailable - try later”. I have to restart the ATV to get it to play anything else.
Any ideas / help much appreciated !
Cheers
Si
