HELP! Stuck with iTunes logo when reconnected to TV
I seemingly run through the entire jailbreak process successfully. My TV is no where near my computer.
Question#1. Do I have to do the tethered boot?
Question#2 TV is no where near my computer? How do I do the tethered boot when I can’t possibly connect apple tv to TV with HDMI cable?
I keep getting the flashing light and connect to iTunes logo.
Any help is greatly appreciated. Not sure what else to do. REALLY want to buy ATVFLASH(Black).
Thanks in advance.
With a tethered boot you HAVE to be able to connect the ATV to the PC/Mac via USB to complete the boot process, and then unplug the USB and plug in the HDMI WITHOUT ever disconnecting the power.   You therefore either need the ATV and PC/Mac to be close to each other or to be using a laptop.
It is likely that an untethered boot will appear at some point which will remove the need to keep the power connected all the time, but the timescale for that is unknown.
Thats my issue. I have to unplug the apple TV from power at my desk then run across the house to reconnect the appletv to my power source where the TV is.
The tethered reboot only works if you never loose power.
Pulling out the laptop. Will let you know. Thank you.
How do I know if the jailbreak worked? Does it change the main menu to the old look (prior to 5.1 update)?
