Help!!!!! problem to jailbreak atv iOS 4.3! Please!!!
file:AppleTV2,1_4.3_8F202_SP_Restore.ipsw
(iTunes 10.2.1)
after doing everything (teorically) correct, this message appears on Seas0onPass:
"iTunes restore script failed!, selecting IPSW in Finder..."
tap on file and nothing, no restore....
please help me
I have the same issue
The troubleshooting guide has been updated with a fix for this issue.
http://forum.firecore.com/topic/3759
If you receive a 'iTunes restore script failed..." message you will need to manually select the IPSW in iTunes (after the AppleTV has been placed into DFU mode). To do this, select the AppleTV from the lefthand column in iTunes, hold down the 'Option' button and click the 'Restore' button. You will then be prompted to select the custom IPSW file (E.G. AppleTV2,1_4.3_8F202_SP_Restore.ipsw) which can be found in your Home folder.
Hi ... I did that until I got a message telling me to disconnect my ATV 2 from my computer and to plug it in my television set.  Doing that, I only get a full black screen.  No Apple logo ...  and clicking on the remote does not bring anything more.  What do I do from there ?
Also have same issue
When I try to select the IPSW in finder, it begins to “packing out”, and then I get the same message again: “iTunes restore script failed!, selecting IPSW in finder…”  What do we do with it?
