HELP Please
This came up on terminal now i have tried to find the fine but no luck ?
Last login: Tue Apr  3 10:54:12 on console
Desmonds-MacBook-Pro:~ desmondwatts$ ssh root@192.168.1.65
@    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that the RSA host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
9a:62:e0:f2:3e:78:7d:55:3d:5f:fc:09:0f:34:68:c1.
Please contact your system administrator.
Add correct host key in /Users/smndwts/.ssh/known_hosts to get rid of this message.
Offending key in /Users/sndwts/.ssh/known_hosts:7
RSA host key for 192.168.1.65 has changed and you have requested strict checking.
Host key verification failed.
That is expected behavior if you have just done a new jailbreak.
Quite how you by-pass it I am not sure.
Ok cheers lets hope someone can help
Have you happened to open the above file and I assume line 7? You likely need to update the RSA key.
How do you do that ?
Well in your explorer you would navigate to the folder /users/YourUsername/.ssh/known_hosts and open it in your text editor.
So user account got that the rest i cant find i am on a mac
That is about as far as I can take you as I don’t have OSX myself.
Cheers buddy 8)
Wait what about in your terminal. If you type cd /uses/YourUsername/.ssh
Are you able to get to the folder then?
No ?  :confused:
Just delete the “known_hosts” file located at /Users/sndwts/.ssh/.
FYI - You may want to back the file up first, then delete it.
Then retry
