You might be able to get your shsh blogs using iFaith 1.4 but I could’nt upload them to the servers and the whole process is quite difficult. There are too many different factors which causes things to not work ie. correct ifaith, old version of seasonpass, itunes etc…
I couldn’t get it jailbroken and i spent hours trying.
I’d suggest that you do a tethered jailbreak of version 5.3 and not bothering to save your shsh blobs - whether or not you’re able to, or interested in, doing a tethered JB of 5.3, you can always reinstall version 4.4.2 (newer than 4.0 - doesn’t require shsh blobs) using this method http://forum.firecore.com/topic/10197 . I’ve done several using 4.4.2 without a problem. I haven’t tried using the new 5.3 JB but lots of people report success so I’m sure it works too.
Augh!!! I just can’t seem to get this thing to jailbreak.
I had mine running fine, then decided to restore everything. Now I dl’ed the Seasonpass and new aTV flash ,but cant seem to get it to do anything.
I’ve tried installing a lower version; nothing. I tried a tethered boot. Nothing. Im running low on patience and there doesnt seem to be a complete guide fro drunken louts anywhere.
LAst time it worked like a charm untethered. With 2.3 its just a cluster$%ck.
Should I try untethered, then immideatly go for tethered? Do I interrupt it somwhere to switch? Do I just go for a tethered boot alone without trying untethered first? (Ive tried those last two, and neither seems to work…)
Im just pissed that I screwed it up and can’t seem to get back to the wonderful world of a jailbroken aTV2
