Help neede with error SW 4.4.3
Does anyone know hoe fix the following error? Please look below. This apple tv 2 is running 4.4.3k below… Thanks so much!!
[[wysiwyg_imageupload:444:]]I tried to post a print screen but it didnt work.
The conflicting software could be your firewall. Shut it down to check that out.
WE SPOKE ABOUT THIS PROBLEM MILLION OF TIME
if u use mac you will not have any error.
if you use window you got to do few steps .fallow this path
go to your      appdata--------local--------temp-----seasonpass-----ifaith   there is file you got to rename
rename the file s5l8930x_Factory.bin to iFaith.s5l8930x_Factory.bin      but do it when ipsw start to be created  .
exit the path and let the process finish
So where is the appdata located in windows 7? Hope this helps…
Go to folder option first and unhide all hidden files.
