Help get (more) Dolby Atmos on Apple TV
Apologies I’m not so technical, but am trying this. Can anyone spot my error?
Part 1: I set up deezy etc and think I got it running, I got a ‘Job Successful’ message and a *.en.EC3 file created.
Part 2: Used mkvmerge to try and replace the audio file with the new one:
.\mkvmerge -o F:\Converted\file.mkv -A F:\Convert\file.mkv F:\Convert\file.en.ec3
While this also seemed to work, what I ended up with was an MKV file 20% smaller than what I started with, and Infuse says the file is still TrueHD, so no Atmos out of the ATV. Would be grateful for any suggestions on what I’m doing wrong.
That mkvmerge command will remove all other existing audio tracks. So that would explain the smaller size. Also, the re-encoded EAC3 audio tracks will be significantly smaller than the original TrueHD track.
You could try manually adding the audio track to the mkv file using MKVToolnix GUI app.
Thanks @ozmbie it all worked using the UI. Must be an incorrect command line in part 2 that I can troubleshoot.
Never had success with DeeZy. Always getting the same error:
ERROR: Unknown filter (encode_to_atmos_ddp).
ERROR: Could not build workflow.
For those interested, there is now an app that appears to internally decodes TrueHD Atmos and DTS:X audio tracks and render it as Dolby MAT output on the AppleTV
If there is any hope of getting this functionality added to Infuse, it would be a perfect addition.
According to a Reddit comment:
More than likely it re-encodes that rendered audio as Apple’s new APAC spatial format and sends it through AVPlayer, which outputs Atmos using Dolby MAT. APAC encoding arrived with tvOS 26, and Native Player both requires tvOS 26 and lists APAC support. So it’s a relatively new feature. I’ve been toying with similar tech in my own app.
For anyone interested: https://developer.apple.com/av-foundation/Apple-Positional-Audio-Codec.pdf
more info: Reddit
Amazing feature…
Awesome, perhaps this can be the solution! At least until Infuse implements external audio track support without having to transcode the video stream.
Made a feature request thread here:
I’m very curious to know if this is a license issue. Since Infuse plays by the rules. But it does seem like it’s no longer a technical limitation to do realtime conversion from TrueHD to Dolby MAT.
That is still lossy so there is a trade off
Looks like Native Player 2.0 is supporting lossless now
Very interesting. They say they support TrueHD and DTS:X with height speakers.
Let’s keep this thread on it’s original track, it’s to have users petition Apple to add more options on the ATV. There are other threads to discuss other options. :+1:
