Help get (more) Dolby Atmos on Apple TV
Update 2/10/20: Infuse now supports Dolby Atmos when using E-AC3 audio tracks.
Dolby Atmos support has been announced at WWDC for tvOS 12!
Unfortunately, the current implementation is only useful for VOD services like iTunes, Netflix, and Vudu. Enabling Atmos for (most) local content is a change that needs to come from Apple, and as the old saying goes “The squeaky wheel gets the grease.” So…we’re asking you to be as squeaky as possible…within reason of course.
Ways you can help
  1. Request a feature or enhancement through apple.com/feedback
  2. Submit an suggestion through Apple’s Feedback Assistant (developers only)*
  3. Sign this petition
  4. Encourage other people you know to do one of the above
A good template of the details to include with your request can be found below.
Dolby Atmos is now supported on Apple TV, which is great! However, the options provided for Atmos are rather limited and not very useful for those who wish to play their own local Atmos content.
Please allow tvOS applications (e.g., Infuse, Plex, DS Video, etc.) to provide more flexible audio options to their users either through the use of Dolby MAT v2.0 or full bitstream audio passthrough.
Devices like NVIDIA SHIELD, Dune 4K, and many other Android-based media players support this feature, and it would be fantastic if the Apple TV would as well.
*Steps for submitting a suggestion through Feedback Assistant
  1. Log in to feedbackassistant.apple.com
  2. Click the Compose New Feedback icon in top nav bar
  3. Select tvOS
  4. Enter the following on the feedback form
    Descriptive title: Support Passthrough Audio for Video File Playback
    Which area are you seeing an issue with?: Audio
    What type of feedback are you reporting?: Suggestion
    What is the audio output?: Other
They didn’t mention if Apple TV 4th gen would support it.
woop woop!
Finally ? Waiting for this for a long time ??
So when do Infuse get updated to support Atmos? ?
Yeah!
Does this means passthrough is coming back?
Yes, it is the question…
Hopefully! But Atmos support might not mean that it works via passthrough. It could just be Atmos metadata with the DD+ audio and could just be limited to Netflix and the iTunes Store for movies. Hopefully not, though! Fingers crossed for passthrough up to TrueHD and DTS MA.
In other forums are saying that for Atmos passtrough is mandatory.
Atmos requires an understanding of how your sound system is set up to figure out what sounds go to which speakers. I’m sure that apps like Infuse could technically decode it, but then passing it to receiver would result in 0 benefit over traditional PCM, non-atmos output.
James, if you are out there, besides Atmos, what else Apple is bringing on this tvos 12 that might be interesting for Infuse users?
We’ll be digging into the 12.0 beta in the coming days to see what sort of useful things we can find.
However, at first glance it doesn’t appear as though Atmos is included in this first build.
Ok, great to hear.:slight_smile:
We´ll be keeping an eye on that.
According to the WWDC blog Atmos will be a free software update.
Can. Not. Wait.
Yes, but as other have speculated, it would not be a surprise if Apple lock the Atmos ability to certain apps (e.g. iTunes, Netflix, etc)
Will have to keep our fingers crossed that that is NOT the case!
Totally! My biggest fear is that Atmos will only apply to iTunes Movies and won’t be open to 3rd party apps (like Netflix can on Xbox).
That would be very much like Apple to do.
How does Apple do Dolby Vision now? I would not be surprised if they did the same thing with Dolby Atmos… their content or blessed apps only.
It seems that Atmos will also be available to developers as the introductory text for tvOS 12 on Apple’s Dev Portal says “Your tvOS apps can deliver amazing experiences […] and immersive sound through Dolby Atmos.”
EDIT: Also, Apple is to provide more information on implementing the new tvOS 12 APIs and technologies in a Session hosted tomorrow at WWDC, so that’ll be useful.
I will be sooooo hanging out for this confirmation tomorrow. FINGERS CROSSED
This news makes me so happy, the perfect player as it seems. Please keep us informed.
Now only the implementation of resolution matching so the tv can do the upscaling.
I wonder how Siri will be able to “talk” during audio passthrough?
