HELP! Freeze at main menu
So i’ve jailbroken a few devices now, but 2 of the recently have “Froze” at the main menu.
After powering on ( or rebooting) the apple tv appears to be frozen.   The light on the device appears to work (I can reset) and it blinks every time i try to hit menu/play or the arrow keys, however the functions on the screen doesn’t respond.  Basically i get to the main menu and then i’m unable to do anything!
I’m running firmware 5.2 on them. I decided to try rejailbreak one of them, later to find out apple isn’t signing off on 5.2
Is there something simple i can do to fix this “freeze”  or do i need to look into restoring the jailbreak using this shsh blobs stuff that i have no idea how to do!
Any and all help is greatly appreciated!  I don’t want to lose the jailbreak on the other device!
you can get those symptoms if you manage to lose the pairing between the remote and the ATV.  I got it once and it took me ages to work out whatnhad gone wrong.  Instructions on resetting this are easily found via Google.
thank you very much! it worked!
