Updated to OS 10.6 snow leopard so I could use SeasonPass and get ATV Flash working.
Set up SeasonPass and all seemed to be going well. Itunes opened and asked to restore. get "iTunes restore script failed!, selecting IPSW in Finder..." message in Seasonpass window. Selected custom restore ispw file which was downloaded. and now I have a flashing light on my ATV2 and when I try either custom or apple restore I get "The Aple TV "Apple TV" could not be restored. An unknown error occurred (1611)
I used the new one but still stuck at the Apple screen. I followed the instructions exactly. How can you tell that the jailbrake worked? If the ATV2 is rebooted do you have to jailbrake all over again?
I did everything as instructed in Jailbreaking 101 on the support page ..... except .... when doing the tethered boot, I ONLY connected the USB before holding menu and play for the 7 seconds and only plugged in the power cable when the screen said the device had entered the DFU mode. Wouldnt work for me with both plugged in at the start of this process and it hung on the "Waiting for device to enter DFU mode...." window.
