Hello everybody,
So here is the situation : I have a 2nd hand atv2 black that was on 5.0 (and presumably never jailbreaked), I updated it today to 5.01 without problem and downloaded last seasonpass version for a untethered jailbreak. I plugged my micro-usb cable and the atv2 light sarted rapidly flashing (as it should) so I launched seasonpass as indicated in the tutorial and it started downloading, unzipping, etc… so far so good.
The problem comes at the end of the procedure : when seasonpass asks me to enter in DFU mode, nothing happens (I press on both buttons for 7 seconds, each time I try windows seven shows me a “USB not recognized” notification but nothing else happens, itunes doesn’t start.
Is my micro-cable functionning ? it’s a cheap blackberry charging cable from ebay and when i plug it to the atv, the light is flashing so I guess everything is OK :-/
Any idea or suggestion ?
Thanking you in advance
