HELP 5.3 (6105)
IS THERE A REASON WHY XBMC IS NOT INSTALLING ON THIS VERSION. IM JAILBROKEN AND TRYING TO INSTALL VIA NITO INSTALLER BUT THE WHEEL KEEPS SPINNING OR IT GIVES ME A CHECK MARK WITH SECONDS BUT NO XBMC INCON
ON VERSION 5.3(6105)
I think the server is very slow today, i manually tried to install via Terminal, which shows you the status, it said it would take over an hour to dl, averaging 10kps, I got up to 64% and I fell asleep and so did the ATV, back to 0% again. I’m trying through Maitenence again, its been spinning for 10 mins now, as long as it doesn’t time out, it should install in a hour or so. If not, the server should hopefully be fixed by tomorrow.
It is working now just installed xbmc.It was xbmc download.org dl speed to slow it’s ok now.
hi, ive been trying for days (literally) to jailbreak 2 apple tv 2s and all i get is “unable to fetch signatures from cydia servers” pls pls PLSSSS can somebody give me a reason for this? is apple still signing 5.3 (6105)
Are you trying to install xbmc through nito ? I just run nito installer and install xbmc no nito tv.
No, I cant jailbreak the atv2 to use nito…
i jb an ATV2 on Sunday night using SP.  Took about 30 minutes with no issues.
