The subtitles work perfectly with Heberw and the synopsis is downloaded correctly.
However, the synopsis should be RTL and right aligned when there’s a hebrew synopsis.
Thanks for the report.
We’ll take a look.
No change in 5.7 although it claims to fix some RTL issues.
The RTL fixes included in 5.7 are a little different, and addressed issues on iOS only.
Full RTL support for tvOS is still on our radar for an upcoming version.
Any update on that? Switched to Hebrew synopsis and while text and artwork are good, the synopsis is still aligned to the left. I wish that could have been addressed, as the rest of the package is awesome. Thanks.
