I have just purchased a Vision Pro and am really impressed with Infuse Pro on it.
Due to a rare condition, I am not able to move my eyes enough to use eye tracking, so I switched to head tracking instad.
While this works great, it comes with a dot as a pointer that (to my knowledge) cannot be turned off.
There is, however, a setting that makes it disappear if you don’t move your ead for a while (you can set a threshold).
This works very well, just not in Infuse :(.
The dot just won’t disappear which is rather annoying and distracting.
If you play a trailer, the dot DOES disappear (I guess cause technically it is a Youtube video?).
I am using a workaround which lets me disable head tracking with a tripple click on the crown but it is still annoying that I have to do this every time I play a videao.
Could you please look into this? I am sure it is just a small thing as, as I said, it works with trailers.
Thanks!
