HDR Playback Issues
ok, i will. Btw, what is the best way as protocol between a nas and Apple TV?
There are many variables in deciding this and that’s why there’s multiple ways to do it. Many (myself included) have very satisfactory results with SMB, and many others prefer FTP or NFS then some use the others for different reasons.
Usually setting SMB to SMB2 or Legacy will give you the best speeds since SMB3 may be adding additional security overhead costing speed.
I’d stick with SMB, FTP, or NFS unless you absolutely need the additional requirements of SFTP or WebDAV. I would not use DLNA or UPnP since those handicap the best parts of Infuse.
Just as an example, my speeds to an ATV4K 1st gen run around the 300+Mbps speeds using SMB on Auto over Ethernet.
Could be possible when my nas had a update of the OS , SMB2 recommended?
Yup or legacy
I am seeing the same issues with HDR/Dolby Vision content lately, did anyone find a solution?
I changed the SMB connection into SMB2. So far, works well
Change the setting from nfs to Samba 2 or legacy still does not solve the problem. Running Ethernet and file transfer rate is around 580mb/s. But notice the movie can playing smoothly when I play straight from the folder ( before add to favourite). Any idea?
Found a temporary fix. Instead of putting all the movies folder from the NAS into 1 folder create in the Infuse favourite, add the folder that contain the movie you have problem playing and you will have no problem.
The trade off is no movie wall and you’ll have to find the right movie file to play from the stream folder.
Firecore team please work out a solution as this is very annoying more and more movie release these day has this problems.
Play the file direct from the stream folder
Guys, any status of this? It’s really frustrating bug :confused:
The 7.5.3 update included a handful of improvements in this area which appears to have resolved the few reports of issues we had here.
Are you using the latest update (7.6.1 released today)? If so, can you describe what you are seeing?
I’m having this exact issue on macOS (13.6.1 & 14.1.1) with Infuse 7.6.2 (7.6.4599) when playing some DV files from Jellyfin. Both iOS (17.1.1) with Infuse 7.6.2 (4599) and iPadOS (17.1.1) with Infuse 7.6.2 (4599) play normally. I’m an Infuse Pro subscriber.
Mediainfo of a problematic file:
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@Main
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hvc1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 2 h 31 min
Bit rate                                 : 16.0 Mb/s
Maximum bit rate                         : 48.0 Mb/s
Width                                    : 3 840 pixels
Height                                   : 1 608 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.108
Stream size                              : 17.0 GiB (95%)
Writing library                          : x265 3.5+147+17-e8947f740:[Windows][MSVC 1937][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=4 / numa-pools=22 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1608 / interlace=0 / total-frames=218462 / level-idc=51 / high-tier=0 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / no-eob / no-eos / hrd / info / hash=0 / temporal-layers=0 / no-open-gop / min-keyint=23 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / no-limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=16000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / vbv-maxrate=32000 / vbv-bufsize=40000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=3 / aq-strength=1.00 / aq-bias-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,20) / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0 / conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass / no-mcstf / no-sbrc
Encoded date                             : 2023-10-11 11:18:02 UTC
Tagged date                              : 2023-10-11 11:18:53 UTC
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0020 cd/m2, max: 1000 cd/m2
mdhd_Duration                            : 9111770
Codec configuration box                  : hvcC+dvvC
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Format settings                          : Dolby Surround EX
Codec ID                                 : ec-3
Bit rate mode                            : Constant
Bit rate                                 : 768 kb/s
Maximum bit rate                         : 811 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 834 MiB (5%)
Title                                    : E-AC-3 7.1
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Alternate group                          : 1
Encoded date                             : 2023-10-11 11:18:50 UTC
