HDR metadata not correct, replaced by standard values
I don’t understand this properly… Is the maxCLL/maxFALL 4000/1000 fixed now?
Chris
I suppose let’s wait till after next week when tvOS 14.5 is officially released
No, only when mastering display SEI info represents DCI-P3. This is specified as a string when encoding with x265, which is parsed when the stream header SEI are emitted.
More info: [link]
I hope @james will look into this.
Doesn’t the beta, pre-release give an indication?
installed the new TVOS 14.5 on my ATV 4k.
In the Netflix and Apple TV+ App I get individual HDR metadata in different movie streams.
In Infuse Pro (latest) I have always the 4000/1000 values in local HDR 4k mkv files.
BR
Erich
We have known this so far. Try my sample with Infuse.
Your link gave me:
ERR_CONNECTION_REFUSED
You knew this also for the final 14.5 version?
My answer was refering to
In terms of metadata the official 14.5 is same as beta.
I uploaded the sample to gdrive too: [link]
We plan to look more into this (IE if anything has changed in tvOS 14.5) after the release of Infuse 7.
Ok!
I think a fix is quite important e.g. for users of JVC projectors, which rely on correct HDR metadata for a proper dynamic tone mapping.
Would be rather helpful, if could look into that soon.
This is pretty sloppy stuff on Apple’s part, I’m surprised it hasn’t gotten more publicity. They have no business debuting new hardware when something as basic as this in tvOS is still broken.
Is the new ATV4K v2 solved the problem?
I believe this is a software problem rather than a hardware issue, but maybe James can clarify.
According to my madVR Envy, the old and the new Apple TV 4K both are sending the correct HDR metadata.
Only with files that mastering display SEI info represents DCI-P3.
Is the issue still present with the new Apple TV 4K 2021?
If I understood correctly it is only on HDR10?
Is the problem present on all HDR TVs? Or only on recent TVs capable of adapting HDR dynamically?
Do you have an example, for which movie this is no the case? Maybe I can check this then (in case I have the movie).
99% of movies are wrong in this case.
I watched 4 movies in the last two weeks and for all the metadata seemed to be okay.
Interesting, I found only two, Spaceballs and Finding 'Ohana.
