HDR color space flag
Hey all.
I have just done my first conversion from a 4K HDR downscale to 1080p HDR ( using Handbrake ).
The result is as expected and it shows with MEDIA INFO as 1080p HDR content. It certainly looks like it’s HDR to my eye.
But in Infuse the file advanced info says it’s SDR and does not have the HDR tag in the preview screen.
If you post the details from mediainfo app about your new file, someone might be able to figure out why.
A common issue that comes up when converting files is that the video will be encoded in 8-bit, when full HDR requires 10-bit. This option doesn’t always get selected correctly in HandBrake.
As @munpip214 mentioned, if you can post the detailed MediaInfo specs here that may provide more insight as to the cause.
