It would be nice if there would be a way to use HDMI and Composite signal simultaneous!!
Is this possible to make sw way or it is hardware??
I’m thinking it is a software issue, but then you also are looking at some low level coding. It might be possible, but I just don’t know enough about the coding on the Apple TV to know if it can be done with a patch.
