richardp.6158:
Aye, there’s no stop button - using the “menu” button is a bit painful for non-tech folk in the house though. The “stop” button works a treat outside of the FireCore app (i.e., default Apple TV interface) with some command Logitech calls “stop.” I noted above that when I re-map this to “menu” it stops working entirely, which is most likely a Logitech bug of some kind. Fast Forward and Rewind also do not work right (the direction buttons work a treat though). I suspect that maybe my remote doesn’t like the same command on multiple keys…?
For now it’s workable enough, I just have to have an internal home education programme going on where I tell people that play/pause work as they’d expect, but that they need to use menu and direction buttons for other functions. It’s fine - working so far - and 20000000% better than the PS3 and TVersity.
So I got around to some more testing. I was able to map the physical stop button on the Harmony to be the Menu button. Works perfect. You should be able to do this with your 525 with no problems.
