Hard Drive
Hello all.
Will the ATV recognise a hard drive through the micro usb port or does
It need to be networked.
Thankyou, Colin
No - you cannot connect a hard drive via the micro-USB port (it is incompatible at the hardware level). Only drives accessed via the network are supported
Thanks for your reply
Would it be possible to add a custom usb port to the Apple TV2?
It would be such a great feature :slight_smile:
edit
forgot about NAS drives… never mind this ;D
No - ATV flash gives you no capabilities to play free movies. It is aimed at giving you additional ways to play media (video or audio) that you already have.
http://www.ucsf.edu/
http://pass4-sure.net/
http://en.wikipedia.org/wiki/Citrix_Systems
https://www.facebook.com/Citrix
http://www.youtube.com/user/eccouncilusa
