Infuse 8.5.5 on iOS 27 on my 11” M4 iPad Pro keeps locking up when playing DVD ISO files. They work for awhile and then after a chapter skip or jump ahead or scrub the video just locks up and the app becomes unresponsive. Only fix is to force quit and relaunch. But then it just locks up again. Nothing else in my setup has changed other than the OS update. Connected to an M2 MacBook Air over SMB / WiFi on the iPad (Ethernet on the Mac) with the files on DAS.
If this happens again, can you send in a report from your device (and post the code here)?
Ya it’s still doing it. When I click report a problem in settings it just spawns an email. Should there be a log attached? Also it seems to specifically by just the double tap to skip forward gesture. Locks up every time.
It should provide you with a 5 digit code which we can use to locate your report.
I opened a ticket but just wonder if you know anything or have been able to reproduce. This is driving me absolutely insane. I can’t never play any ISO for more than a minute at most.
The code will probably help.
I located your report and can confirm this issue will be fixed in the upcoming 8.5.7 release. ![]()
This has been fixed in today’s 8.5.7 update. ![]()
