Global settings
How do I set subtitles and audio globally and not for every single movie ? I wish to disable Dolby and use normal subtitles instead of bold.
Also how do I change subs size in airplay ?
Global language settings are coming in the next version.
Subtitle display settings will need to be set in the Apple TV Settings menu. There are quite a few customizable options there, so you can fine tune their appearance to your liking.
[quote="james"]
[/quote]
where are those settings, I don't see anything related to subtitles size. I am on latest Apple TV 3.
The subtitle appearance settings can be found on the Apple TV in the Settings > General > Accessibility menu.
Scroll down to the Subtitles & Captioning section, and select the Style item.
