Without adding the TMDB tag to my file, what should Ghostbusters (2016) be labeled as so it gets the correct metadata?
– It’s currently coming up as the 1984 edition.
Ghostbusters 2016.mkv worked for me. If it didn’t match right the first time you’ll need to do an edit metadata and select the correct one. That correction will stick.
