I acquired a used ATV G1 that had Firecore installed. I connected a keyboard and goty it working under AppleTV menus, however when I go to XBMC or Boxee and press a key, it is as if I had pressed it twice. This is primarily on navigation as I have manually entered network addresses with no issues.
I have so far tried in XBMC...
Tried disableing "allow Local programs on theis machine to control XBMC" and this meant that the Apple remote no longer worked.
Option for "Remote sends keyboard presses", and noted no change
Disabled the option for "Magic Keyboard" in ATV menus, and both XBMC and Boxee worked with keyboard , but no apple TV keyboard.
Is there a way I can usee the keyboard and remote across all of the programs without double key presses? I suspect OS and XBMC are interpreting the same keyboard press based on tests above.
