FTP, SSH AFP, not function
After a blocking apptv, I had to reinstall atvflash. Now I have more problems thanthe initial installation. I can not access apptv and ext hdd via FTP. I can notenable or disable services SSH, FTP and AFP. How can I fix it?
In Management services, FTP access is ON but when I try to disable it says "FTP MISSING, can not enable" while the other is marked OFF and warns me not to be able to activate. (?)
Thanks.
Leonardo
Now, it's ok.
I installed everything from the beginning.
AppTv reset, updated AppTv original file, atvflash installed via usb.
Installed and updated files "maintenance" from apptv.
Now worked all: ftp, ext hdd and various video files.
Bye from Italy :-)
hi,
i'm having the same problem like you. only that i started from using patch stick and get to atvflash later. How do you do atv reset, update original file? Not sure how to do that...
Ciao LEO…
I do have exactely the same problem.
II have everthing updated and instaleld but I can not SSH nor FTP.
My ATV Gen1 is working fine and even making good syncs with ITUNE (ver 10.X ) . I do have all domain APPLE at home and all devices are in the same Wifi net, just in case.  Any advice _  appreciated.
FTP and SSH are enabled by default when installing aTV Flash.
If you’re having trouble connecting you may try re-installing aTV Flash using a USB flash drive.
