I use FTP protocol to connect to my dediseedbox. (Infuse latest version on Apple TV). Since one week the connection doesn’t work. Using FileZilla with same credentials work. Is there a bug on latest version of Infuse?
Since both Infuse and tvOS have frequent updates it’s usually best to give the actual version numbers when working on an issue.
One thing to check is the address you’re using in Infuse. Are you using the IP number address or a text address like mynas.local?
If you use the IP address you’ll want to make sure you have assigned a static address for your NAS. If you’re using the name like mynas.local then make sure your router hasn’t added a second address for your NAS likemynas2.local which happens sometimes when there’s a network interruption and the first name wasn’t released.
Version of TvOS: 26.5
Infuse : 8.4.7
The FTP is a dediseedbox, with an static ip. The access work from FileZilla on my macos
