newb question. I’ve used the search but found nothing.
my atv installation doesn’t accept my ftp credentials frontrow/frontrow. I’m able to connect to the atv and it likes the username, but doesn’t accept the password - failed authentication. This is a new installation so should be default.
Anyone got any pointers or ideas how i can load content?
here’s my log:
Status: Connecting to 10.0.1.9:21…
Status: Connection established, waiting for welcome message…
Response: 220---------- Welcome to Pure-FTPd [TLS] ----------
Response: 220-Local time is now 23:01. Server port: 21.
Response: 220-IPv6 connections are also welcome on this server.
Response: 220 You will be disconnected after 15 minutes of inactivity.
Command: USER frontrow
Response: 331 User frontrow OK. Password required
Command: PASS ********
Error: Could not connect to server
software version 3.02.
NitoTV is version 0.9.4
ATV flash version 4.1.5
I’ve also tried ftp’ing using ethernet and a crossover cable (and again, using the direct IP address).
here’s the thing, If I go to NitoTV > settings > Utilities > Services > FTP access, the FTP Access service is listed as “On” but if I select this service to change it, I ge tthe error message “FTP Missing, cannot enable”. The same error message is returned when I attempt to enable AFS. I can’t enable SSH either (nothing happens).
