French Subtitle Issues
I’ve got a issue with the french subtitles: some specifics french characters are changing like the “ç” into À. It’s very annoying… Is there some kind of special set up to do to avoid this kind of problem? Thanks.
Yes, you may need to adjust the subtitle encoding type as described in the guide below.
For French I would suggest using one of the Western European options.
Thanks. Working perfect!
