Frasier 2023
Running into a bit of trouble trying to name these files. Should it live in the same folder a the old series or be a new thing independently?
Kind Regards
Best bet would be to do a new folder and to name the files ā€œFrasier 2023 S0xE0x.mkvā€ for the episodes and ā€œFrasier 2023ā€ for the series folder.
And just to keep things in order I’d rename the original to include the year also ā€œFrasier 1993 S0xE0x.mkvā€ for the episodes and ā€œFrasier 1993ā€ for the series folder.
TMDB shows them as different series.
Thanks so much.
