Frame rate for iOS playback via HDMI
I’m using an iPhone 15 Pro with a USB-C to HDMI connection to play videos on a 4k TV. If I play a movie from Apple’s own TV app then it will play at 4K HDR with the frame rate matching the source material (eg. 24fps). However, if I play a similar video on Infuse Pro then it will still play at 4K HDR but the frame rate is always 60fps, which means that you see micro-stutters as the video plays.
Is this a limitation of Infuse, or is there some setting I’m missing?
A post was merged into an existing topic: Automatic Frame Rate and Dynamic Range Switching Over HDMI (iOS/iPadOS)
