When playing back 8K HDR10 video with Infuse Pro (8.1.6) and MBP14 (2024, macOS15.5) internal monitor, I noticed frequent stutter. I recorded a slow motion video and realized that the problem should be unstable frame pacing. Then I tried playing the 8K HDR10 video on the internal monitor in other modes and an external monitor in SDR/HDR mode, the stutter problem only occurs when internal monitor in “Apple XDR Display” or “Apple Display” and external monitor in SDR mode. I assume the stutter problem is related to tonemapping. Can Infuse fix this or it’s Apple’s responsibility?
8K HDR10 video mediainfo:
General
Complete name : Cyberpunk 8K HDR RTX Afterlife.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/mp41)
File size : 1.67 GiB
Duration : 2 min 29 s
Overall bit rate : 95.8 Mb/s
Frame rate : 60.000 FPS
Writing application : Lavf57.25.100
Video
Format : HEVC
Format profile : Main 10@L6.1@Main
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 95.6 Mb/s
Width : 7 680 pixels
Height : 4 320 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.048
Stream size : 1.66 GiB (100%)
Color range : Full
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
MaxCLL_Original : 65535 cd/m2
Maximum Frame-Average Light Level : 400 cd/m2
MaxFALL_Original : 65535 cd/m2
SEI_rbsp_stop_one_bit : Missing
Codec configuration box : hvcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration_LastFrame : -15 ms
Bit rate mode : Constant
Bit rate : 196 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 3.49 MiB (0%)
Default : Yes
Alternate group : 1
Slow motion screenshot video showing the unstable frame pacing:
