I wondered if anyone knew of a way to install fox on demand for the couch surfer?
I’m using the latest aTV flash.
I go to fox.com, select the show I want to watch, a message comes up asking whether I want to install the media player, I click yes and the appletv reboots. When it comes back the media player hasn’t installed. I have flash working etc.
Any ideas? I missed Prison Break this week because the satellite dish got covered in snow and I don’t want to have to watch it on my laptop.
I too would like some input on Fox’s version of flash player. I’ve finally, after two months of trying, gotten Flash player to work on my Apple TV. Now I get nothing on the Fox on Demand site. Please help!
I am on ATVflash 3.1, so I don’t have the Maintenance option on my menu, and I am not ready to upgrade yet so I am stuck trying to enable flash manually.
I copied the CoreAudiokit.framework file to System/Library/Frameworks directory but that didn’t seem to work.
Then madcran suggested the following.
sudo mv CoreAudioKit.framework /System/Library/Frameworks
Then:
sudo chown -R root:wheel /System/Library/Frameworks/CoreAudioKit.framework
sudo chmod -R 0755 /System/Library/Frameworks/CoreAudioKit.framework
The command seemed to take. I even made the root writeable before hand, but no luck,
Any thoughts would be appreciated.
TPH
