Hi, I’m a new user and have a share of movies and other ripped DVDs that I pointed at with Infuse. It includes some workout videos. Is there a way to get the workout videos to show up under Other rather than Movies?
Thanks.
Thanks.
Are they being correctly identified and given the right name and info in the library?
Yes, it is pulling in the Metadata, the file is named Jillian Michaels_ 30 Day Shred-1.m4v and it correctly matches with this Jillian Michaels: 30 Day Shred (TV Series 2008- ) — The Movie Database (TMDB)
My issue is that it is clearly not a movie and was hoping I could force it to appear under Other rather than Movies.
Thanks.
You could create a new favorite and place all of the videos you don’t want into that favorite and then uncheck that favorite in the library settings. Those videos won’t be included in your library and you can place that favorite on the home screen if you like.
You could also tag that folder as “Local”
That being said, that particular show you referenced should be a TV show and not a movie. It should have a name like
“Jillian Michaels 30 Day Shred 2008 S01E01.mkv”
and you should have 3 episodes according to the TMDB page. That would also keep it out of movies and place it in TV shows as it should be.
