Forceclosing on icloud restore
Hi there, I have the pro subscription for Infuse and on my main apple tv it shows purchased as well as my two plex servers. I have backed that up to the icloud. Then I go to the apple tv in my office and I can do the subscripption restore and it shows the pro paid subscription, so that works fine… but when I go to restore the icloud backup, it forececloses back to the main apple tv screen. Any way to get that working? or do i need to just readd them manually again?
Cloud backups are specific to that device and won’t be accessible on other devices. This is different than iCloud Sync which can be used across different devices.
To create a cloud backup for your second device so it’s available for the future, you can navigate to Infuse > Settings > Cloud Backup.
More info on using iCloud Sync and Cloud Backup can be found here.
