Hey folks, I’m trying to use folder-based organization for extras on OneDrive, but it’s not getting correctly identified by Infuse. Infuse identifies all files in the “Behind The Scenes”/“Interviews”/etc. folder as separate movies.
The same exact organization structure can be correctly identified by Infuse if I store the files on iCloud Drive instead of OneDrive
Example folder structure that’s not getting correctly identified on OneDrive:
Baraka (1992)/
Baraka (1992).mkv
Behind The Scenes/
A Close Look.mkv
Restoration.mkv
This seems like a bug with how infuse processes OneDrive data?
