Flickering library screen
Hi I’ve recently started using Infuse and loving it, but have a problem I hope you can help with. The Library menu screens where the left 2/3 of the screen should show an artwork carousel are now just flickering artwork images at a very high rate. Like high enough to induce epileptic fit high! Any idea how I can fix this? Please don’t say reinstall as I’ve spent about 2-3 hours fixing metadata…
Thanks.
Hmm, can you try force-quitting the app to see if this helps?
A bit more info on doing this can be found here.
