Fixing permissions?
I am trying to fix the problem outlined in this thread here: http://forum.firecore.com/topic/5483
Apparently the solution is to fix the apple tv’s permissions but I am not quite sure how to do that.
Could anyone explain to me how to do this?
you need to ssh into atv, I use putty, and chmod the files you want to fix, do a search on xbmc forum
Thanks for the reply. I figured it out.
For other noobs like myself who need to do the same thing:
Go into terminal and type: ssh root@xxx.xxx.x.xx (xs are your apple tv’s ip address)
type alpine for the password
then type: chmod 0755 /private/var/root/
and your done.
Now I am not sure at all if thats the normal way to do it but it worked for me.
