This is probably a bit of a newbie question. I have a TV special for a certain show that is showing up in my Movies collection.
How can I get it out of Movies and into TV Shows? I can’t find any results for meta data, so I know I have to create something on my own.
Thanks!
TL;DR Your TV shows probably do not contain a recognizable pattern, like “S##E##.” Rename them so they do.
TV specials are “season 0” so your file should be named S00Exx. As for the xx you can check the tvdb what the episode number should be
