Firmware Restore Failed
I am trying to Jailbreak my ATV2. When I get to the step to it is restoring Apple TV firmware, I get the following error message “firmware restore failed”
When I hit OK in the dialog box it goes back to the beginning screen. I am trying to do this on a PC and this is the first time that I am trying to JB an Apple device so I am a little clueless on what to do next. I tried searching but didn’t find any good info.
Please help… Thanks.
I had the same issue yesterday. Turned out to be either the USB cable I was using or iTunes not running in the background all the time. Not sure which one helped as I did both of those things when it suddenly worked. I followed the guide on this page step by step - so the guide should be fully functional. I tried four times before with the same issue you are having,
