firmware backup icons missing after update to aTV flash 1.3
Ok, i noticed the 1.3 aTVflash upgrade,and was pleased to see mention of firmware backups. awesome addition!
So i went into settings/manage extras  ,where the new icons should be, and nothing has changed.
no option to backup firmware… =(
next i checked the “about” option, and it shows i am running 1.3  flash.
what’s going on…? any ideas?
best regards and thank you.
SOLVED THANKS
Sorry for the confusion. The firmware backup option can be found in the Maintenance --> Settings --> Manage Backups menu.
thanks for clearing that up, James =)
support is second to none @ FC
