I have 3 files in my library with question marks at the end of their file names that are the only three files that aren’t automatically identified by Infuse. Two examples are:
- Batman The Animated Series s01e41 - If You're So Smart, Why Aren't You Rich?.avi
- Batman The Animated Series s01e45 - What Is Reality?.avi
These are the correct episode names and numbers according to thetvdb.com, and there is no local metadata for any of the files (xml or in-file). In Infuse the files are listed as “B4U3TY~6.avi” and “BFEQ46~P.avi” for some reason. Trying to edit the metadata in Infuse doesn’t work, as searching for “Batman The Animated Series” returns no results. Is there something I can do so that Infuse will identify these files correctly? Renaming the files isn’t an option, as Infuse is just one of a handful of media end points, and I’d rather not have to update a number of other places just because Infuse isn’t identifying these few files. Thanks in advance for any help.
