File Systems Patches Failed (OSX 10.11.1) Help Needed (please!!!!)
Hi All,
I am having huge problems JB my apple tv2 after it threw a fit.
I have restored the atv to 5.3 but cannot jailbrake despite several attempts :frowning:
I have tried version 0.97, 0.96, 0.95 but keep getting the file systems patches failed every time??? I am using OSX 10.11.1 (El Capitan)
I have looked at other postings on the forums regarding this error and have tried a different machine (running OSX 10.11.1) and i have even tried running windows 10 on parallels which goes further but I end up with a ā€œError entering DFUā€ (despite SP seeing the device in DFU mode!!!)
I have also tried doing the jailbrake with the power cable attached and without the power cable attached.
Any help would be gratefully received before I lose the will to live!!!
p.s. this unit was Jail broken previously and worked fine until it got itself stuck in recovery mode.
I have the same problem, there is no problems going to 6.2.1 but thats TETHERED and i dont want that :slight_smile:
Some pls help us
I am having the same problem… DYING HERE! HElp anyOne?
Yup, same problem here.
ItĀ“s the file system om 10.11.1 that’s giving us problems.
So setup a lower version of OS X or maybe you have a friend that has one.
