FF and RW skipping 3 minutes or more
For infuse on Apple TV when you click left or right the video ff and rw 3 minutes or more. It’s frustrating because you usually want to scrub 10 to 15 seconds. You can hold down to scrub faster or pause and scrub for long skips as a solution for people who want to scrub more. The default scrub should be 10 or 15 seconds like all the other Apple TV apps.
Change the Chapter Controls in settings to “Off”
With chapter controls “on” it will skip to the next chapter in the video. Off it has 10/15s skips.
That did it. Thanks.
