Fetch Movie data not working
Hello
I have been using MiRow since it was released. It has been working great no problems. Last night i added a few new movies and now Fetch Movie Data only finds the same movie list no mater what movie it is looking for info on. Ive upgraded to 1.0.4. ive restarted Front Row. moved the new movies to a new location. Cleared Meta data. Still It finds the same movies to select from which are wroung. any way to reset to the results returned by a new search of the IMDB system.
help
What type of files are you downloading metadata for?
Do you currently have the 'Use Directory Lookup' option enabled in the Media > Settings menu?
