hello! i’m fairly new, but i managed to sort everything out with metadata and my own local posters/artwork. my local artwork works for movie posters + fanart, and then tv show posters. for some reason, i can’t get fanart to work for tv shows. here’s how i’ve got everything set up. everything works EXCEPT for tv show fanart and it’s driving me mental… i’ve got them setup the same but nothing changes. i’ve tried putting the fanart into the season folder, but that never changes anything either. any help would be appreciated.
did you use cloud drive?
no, it’s just a local folder
which infuse version
newest version available as i just downloaded infuse for the first time yesterday. its says Version 8.5.1 (8.5.5726)
In the metadata settings, turn on local covers and clear the cache to give it a try.
nothing changed unfortunately ![]()
can you upload fanart.jpg , I will try
wow i’m feeling betrayed
i might delete the app and try again
maybe need infuse pro![]()
gosh i hope not… it works for movies so i’m not sure why it won’t work for my tv shows
infuse pro support trial, maybe you can try and cancel sub
