Failed to reset USB Counters
I’ve updated to 6.2.1 and jailbroken with Seasonpass.
When booting tethered, it shows message “Failed to reset USB Counters.”
I’ve gotten this message numerous times, which I’ve been able to work around with the exception of the tethered boot.
I’ve restored the firmware in iTunes and started all over with seasonpass but still get this message at tethered boot.
Ideas??
Reboot your OS.
Done that a bunch of times already. I’ve been jailbreaking since patchstick and have never seen this message before.
Same here. iMac (2007) · ElCaptain (10.11.2 Beta (15C27e)) · Seas0nPass_097_860_beta · ATV 2
Need Help!!!
Same here
Macbook core duo, el captain, apple tv 2, 6.2.1 and seasonpass 0.9.7 beta
Application Support/Seas0nPass/Firmware/AppleTV2,1_6.2.1_11D258_SP_Restore_948400115086
2015-10-31 21:00:43.547 Seas0nPass[422:5814] device_detached!
2015-10-31 21:00:43.547 Seas0nPass[422:5814] device attached!
2015-10-31 21:00:43.549 Seas0nPass[422:5814] CPID: 35120
2015-10-31 21:00:43.549 Seas0nPass[422:5814] BDID: 16
2015-10-31 21:00:43.549 Seas0nPass[422:5814] ECID: 0xDCD10D4D8E
2015-10-31 21:00:43.550 Seas0nPass[422:5814] open_device
2015-10-31 21:00:43.550 Seas0nPass[422:5814] [CONNECTED] VID: 0x05ac / PID: 0x1281
2015-10-31 21:00:43.550 Seas0nPass[422:5814] status: 0
2015-10-31 21:00:43.552 Seas0nPass[422:5814] device pid: 4737
2015-10-31 21:00:43.552 Seas0nPass[422:5814] stop_notification_monitoring
2015-10-31 21:00:43.552 Seas0nPass[422:5814] closing interface
2015-10-31 21:00:43.553 Seas0nPass[422:5814] USBDeviceClose
2015-10-31 21:00:44.555 Seas0nPass[422:3996] <tetherKitAppDelegate: 0x7fbff1c5d540> DFUWrapper
2015-10-31 21:00:44.556 Seas0nPass[422:3996] device_detached!
2015-10-31 21:00:44.556 Seas0nPass[422:3996] device attached!
2015-10-31 21:00:44.558 Seas0nPass[422:3996] CPID: 35120
2015-10-31 21:00:44.558 Seas0nPass[422:3996] BDID: 16
2015-10-31 21:00:44.558 Seas0nPass[422:3996] ECID: 0xDCD10D4D8E
2015-10-31 21:00:44.558 Seas0nPass[422:3996] open_device
2015-10-31 21:00:44.559 Seas0nPass[422:3996] [CONNECTED] VID: 0x05ac / PID: 0x1281
2015-10-31 21:00:44.559 Seas0nPass[422:3996] status: 0
2015-10-31 21:01:07.707 Seas0nPass[422:3996] device_detached!
2015-10-31 21:01:07.708 Seas0nPass[422:3996] in detach iterator
2015-10-31 21:01:07.708 Seas0nPass[422:3996] device with location id: 605028352 detached
2015-10-31 21:01:07.708 Seas0nPass[422:3996] closing interface
2015-10-31 21:01:07.708 Seas0nPass[422:3996] USBDeviceClose
2015-10-31 21:01:07.709 Seas0nPass[422:3996] [DISCONNECTED]
2015-10-31 21:01:08.241 Seas0nPass[422:3996] device attached!
2015-10-31 21:01:08.247 Seas0nPass[422:3996] CPID: 35120
2015-10-31 21:01:08.247 Seas0nPass[422:3996] BDID: 16
2015-10-31 21:01:08.247 Seas0nPass[422:3996] ECID: 0xDCD10D4D8E
2015-10-31 21:01:08.247 Seas0nPass[422:3996] open_device
2015-10-31 21:01:08.264 Seas0nPass[422:3996] [CONNECTED] VID: 0x05ac / PID: 0x1227
2015-10-31 21:01:08.265 Seas0nPass[422:3996] status: 0
2015-10-31 21:01:08.651 Seas0nPass[422:6826] SHATTERING
2015-10-31 21:01:08.652 Seas0nPass[422:6826] shatter_user.ecid: 948400115086, Device->ecid: 948400115086
2015-10-31 21:01:08.652 Seas0nPass[422:6826] shatter_user.bdid: 16, Device->bdid: 16
2015-10-31 21:01:08.652 Seas0nPass[422:6826] shatter_user.cpid: 35120, Device->cpid: 35120
2015-10-31 21:01:08.653 Seas0nPass[422:6826] shatter status: 1
2015-10-31 21:01:08.654 Seas0nPass[422:6826]
[!] Exploiting with SHAtter… [!]
2015-10-31 21:01:08.670 Seas0nPass[422:6826] [.] PASS_1
2015-10-31 21:01:08.686 Seas0nPass[422:6826] [.] Preparing Oversize…
2015-10-31 21:01:08.705 Seas0nPass[422:6826] [.] resetting counters…
2015-10-31 21:01:08.706 Seas0nPass[422:6826] [.] shifting DFU_UPLOAD count…
2015-10-31 21:01:09.710 Seas0nPass[422:6826] [.] resetting DFU.
2015-10-31 21:01:09.711 Seas0nPass[422:6826] reset_device
2015-10-31 21:01:11.723 Seas0nPass[422:6826] [ERROR] DeviceRequestTO failed with code 0xe0004051
2015-10-31 21:01:11.723 Seas0nPass[422:6826] get_status
2015-10-31 21:01:12.725 Seas0nPass[422:6826] [ERROR] DeviceRequestTO failed with code 0xe0004051
2015-10-31 21:01:12.725 Seas0nPass[422:6826] get_status
2015-10-31 21:01:13.727 Seas0nPass[422:6826] [ERROR] DeviceRequestTO failed with code 0xe0004051
2015-10-31 21:01:13.727 Seas0nPass[422:6826] get_status
2015-10-31 21:01:14.728 Seas0nPass[422:6826] [ERROR] DeviceRequestTO failed with code 0xe0004051
2015-10-31 21:01:14.729 Seas0nPass[422:6826] reenumerate_device
2015-10-31 21:01:14.809 Seas0nPass[422:3996] device_detached!
2015-10-31 21:01:14.810 Seas0nPass[422:3996] in detach iterator
2015-10-31 21:01:14.810 Seas0nPass[422:3996] device with location id: 605028352 detached
2015-10-31 21:01:14.810 Seas0nPass[422:3996] closing interface
2015-10-31 21:01:14.811 Seas0nPass[422:3996] USBDeviceClose
2015-10-31 21:01:14.811 Seas0nPass[422:3996] [DISCONNECTED]
2015-10-31 21:01:14.809 Seas0nPass[422:6826] finished transfer with status: 0
2015-10-31 21:01:14.811 Seas0nPass[422:6826] stop_notification_monitoring
2015-10-31 21:01:15.813 Seas0nPass[422:3996] device attached!
2015-10-31 21:01:15.816 Seas0nPass[422:3996] CPID: 35120
2015-10-31 21:01:15.816 Seas0nPass[422:3996] BDID: 16
2015-10-31 21:01:15.816 Seas0nPass[422:3996] ECID: 0xDCD10D4D8E
2015-10-31 21:01:15.816 Seas0nPass[422:3996] open_device
2015-10-31 21:01:15.817 Seas0nPass[422:3996] [CONNECTED] VID: 0x05ac / PID: 0x1227
2015-10-31 21:01:15.817 Seas0nPass[422:3996] status: 1
2015-10-31 21:01:15.817 Seas0nPass[422:3996] SHATTERING
2015-10-31 21:01:15.817 Seas0nPass[422:3996] shatter_user.ecid: 948400115086, Device->ecid: 948400115086
2015-10-31 21:01:15.818 Seas0nPass[422:3996] shatter_user.bdid: 16, Device->bdid: 16
2015-10-31 21:01:15.818 Seas0nPass[422:3996] shatter_user.cpid: 35120, Device->cpid: 35120
2015-10-31 21:01:15.818 Seas0nPass[422:3996] shatter status: 2
2015-10-31 21:01:17.080 Seas0nPass[422:3996] [.] Exploit data successfully sent!
2015-10-31 21:01:18.175 Seas0nPass[422:3996] [.] SHA1 registers pointed to 0x0.
2015-10-31 21:01:19.185 Seas0nPass[422:3996] CPID: 35120
2015-10-31 21:01:19.185 Seas0nPass[422:3996] BDID: 16
2015-10-31 21:01:19.185 Seas0nPass[422:3996] ECID: 0xDCD10D4D8E
2015-10-31 21:01:19.185 Seas0nPass[422:3996] open_device
2015-10-31 21:01:19.186 Seas0nPass[422:3996] [CONNECTED] VID: 0x05ac / PID: 0x1227
2015-10-31 21:01:19.186 Seas0nPass[422:3996] status: 2
2015-10-31 21:01:19.187 Seas0nPass[422:3996] SHATTERING
2015-10-31 21:01:19.187 Seas0nPass[422:3996] shatter_user.ecid: 948400115086, Device->ecid: 948400115086
2015-10-31 21:01:19.187 Seas0nPass[422:3996] shatter_user.bdid: 16, Device->bdid: 16
2015-10-31 21:01:19.187 Seas0nPass[422:3996] shatter_user.cpid: 35120, Device->cpid: 35120
2015-10-31 21:01:19.187 Seas0nPass[422:3996] shatter status: 3
2015-10-31 21:01:19.187 Seas0nPass[422:3996] [.] PASS_2
2015-10-31 21:01:19.192 Seas0nPass[422:3996] [.] preparing oversize…
2015-10-31 21:01:19.200 Seas0nPass[422:3996] reset_device
2015-10-31 21:01:19.826 Seas0nPass[422:6826] <tetherKitAppDelegate: 0x7fbff1c5d540> DFUWrapper
2015-10-31 21:01:19.828 Seas0nPass[422:6826] device_detached!
2015-10-31 21:01:20.202 Seas0nPass[422:3996] [ERROR] DeviceRequestTO failed with code 0xe0004051
2015-10-31 21:01:20.202 Seas0nPass[422:3996] get_status
2015-10-31 21:01:20.831 Seas0nPass[422:6826] device attached!
2015-10-31 21:01:21.204 Seas0nPass[422:3996] [ERROR] DeviceRequestTO failed with code 0xe0004051
2015-10-31 21:01:21.204 Seas0nPass[422:3996] get_status
2015-10-31 21:01:26.205 Seas0nPass[422:6826] [ERROR] DeviceRequest failed with code 0xe0004051
2015-10-31 21:01:26.205 Seas0nPass[422:6826] send_control_request_failed!!!
2015-10-31 21:01:26.206 Seas0nPass[422:6826] open_device
2015-10-31 21:01:26.206 Seas0nPass[422:6826] [ERROR] USBDeviceClose failed with code 0xe00002cd
2015-10-31 21:01:26.206 Seas0nPass[422:6826] [ERROR] USBDeviceOpenSeize failed with code 0xe00002cd
2015-10-31 21:01:26.206 Seas0nPass[422:6826] try to get ids again!
2015-10-31 21:01:27.206 Seas0nPass[422:3996] [ERROR] DeviceRequestTO failed with code 0xe0004051
2015-10-31 21:01:27.206 Seas0nPass[422:3996] get_status
2015-10-31 21:01:32.207 Seas0nPass[422:6826] [ERROR] DeviceRequest failed with code 0xe0004051
2015-10-31 21:01:32.207 Seas0nPass[422:6826] send_control_request_failed!!!
2015-10-31 21:01:32.208 Seas0nPass[422:6826] status: 1
2015-10-31 21:01:32.208 Seas0nPass[422:6826] SHATTERING
2015-10-31 21:01:32.208 Seas0nPass[422:6826] shatter_user.ecid: 948400115086, Device->ecid: -1
2015-10-31 21:01:32.208 Seas0nPass[422:6826] shatter_user.bdid: 16, Device->bdid: -1
2015-10-31 21:01:32.209 Seas0nPass[422:6826] shatter_user.cpid: 35120, Device->cpid: -1
2015-10-31 21:01:33.207 Seas0nPass[422:3996] [ERROR] DeviceRequestTO failed with code 0xe0004051
2015-10-31 21:01:33.207 Seas0nPass[422:3996] reenumerate_device
2015-10-31 21:01:33.214 Seas0nPass[422:7185] SHATTERING
2015-10-31 21:01:33.215 Seas0nPass[422:7185] shatter_user.ecid: 948400115086, Device->ecid: -1
2015-10-31 21:01:33.215 Seas0nPass[422:7185] shatter_user.bdid: 16, Device->bdid: -1
2015-10-31 21:01:33.215 Seas0nPass[422:7185] shatter_user.cpid: 35120, Device->cpid: -1
2015-10-31 21:01:33.288 Seas0nPass[422:3996] finish transfer finished with status: 0
2015-10-31 21:01:33.289 Seas0nPass[422:3996] [.] resetting DFU.
2015-10-31 21:01:33.294 Seas0nPass[422:3996] stop_notification_monitoring
2015-10-31 21:01:38.295 Seas0nPass[422:3996] <tetherKitAppDelegate: 0x7fbff1c5d540> DFUWrapper
2015-10-31 21:01:38.296 Seas0nPass[422:3996] device_detached!
2015-10-31 21:01:39.296 Seas0nPass[422:3996] device attached!
2015-10-31 21:01:39.300 Seas0nPass[422:3996] CPID: 35120
2015-10-31 21:01:39.300 Seas0nPass[422:3996] BDID: 16
2015-10-31 21:01:39.300 Seas0nPass[422:3996] ECID: 0xDCD10D4D8E
2015-10-31 21:01:39.300 Seas0nPass[422:3996] open_device
2015-10-31 21:01:39.301 Seas0nPass[422:3996] [CONNECTED] VID: 0x05ac / PID: 0x1227
2015-10-31 21:01:39.301 Seas0nPass[422:3996] status: 1
2015-10-31 21:01:39.301 Seas0nPass[422:3996] SHATTERING
2015-10-31 21:01:39.301 Seas0nPass[422:3996] shatter_user.ecid: 948400115086, Device->ecid: 948400115086
2015-10-31 21:01:39.302 Seas0nPass[422:3996] shatter_user.bdid: 16, Device->bdid: 16
2015-10-31 21:01:39.302 Seas0nPass[422:3996] shatter_user.cpid: 35120, Device->cpid: 35120
2015-10-31 21:01:39.302 Seas0nPass[422:3996] shatter status: 2
2015-10-31 21:01:40.603 Seas0nPass[422:3996] [.] Exploit data successfully sent!
2015-10-31 21:01:41.701 Seas0nPass[422:3996] [.] SHA1 registers pointed to 0x0.
2015-10-31 21:01:42.712 Seas0nPass[422:7291] SHATTERING
2015-10-31 21:01:42.712 Seas0nPass[422:7291] shatter_user.ecid: 948400115086, Device->ecid: 948400115086
2015-10-31 21:01:42.713 Seas0nPass[422:7291] shatter_user.bdid: 16, Device->bdid: 16
2015-10-31 21:01:42.713 Seas0nPass[422:7291] shatter_user.cpid: 35120, Device->cpid: 35120
2015-10-31 21:01:42.713 Seas0nPass[422:7291] shatter status: 3
2015-10-31 21:01:42.714 Seas0nPass[422:7291] [.] PASS_2
2015-10-31 21:01:43.715 Seas0nPass[422:3996] [ERROR] IOCreatePlugInInterfaceForService failed with code 0xe00002be
2015-10-31 21:01:43.717 Seas0nPass[422:3996] device_detached!
2015-10-31 21:01:43.717 Seas0nPass[422:3996] in detach iterator
2015-10-31 21:01:43.718 Seas0nPass[422:3996] device with location id: 605028352 detached
2015-10-31 21:01:43.718 Seas0nPass[422:3996] closing interface
2015-10-31 21:01:43.718 Seas0nPass[422:3996] USBDeviceClose
2015-10-31 21:01:43.718 Seas0nPass[422:3996] [DISCONNECTED]
2015-10-31 21:01:43.722 Seas0nPass[422:7291] [.] preparing oversize…
2015-10-31 21:01:43.737 Seas0nPass[422:7291] Device->enabled == false
2015-10-31 21:01:43.738 Seas0nPass[422:7291] failed to reset USB counters.
here the same…
Nov 1 15:08:02 BildAir Seas0nPass[512]: <tetherKitAppDelegate: 0x7f9b68d49c90> tetheredDFUWrapper
Nov 1 15:08:02 BildAir Seas0nPass[512]: device_detached!
Nov 1 15:08:03 BildAir Seas0nPass[512]: device attached!
Nov 1 15:08:03 BildAir Seas0nPass[512]: CPID: 35120
Nov 1 15:08:03 BildAir Seas0nPass[512]: BDID: 16
Nov 1 15:08:03 BildAir Seas0nPass[512]: ECID: 0x267F102CDCC
Nov 1 15:08:03 BildAir Seas0nPass[512]: open_device
Nov 1 15:08:03 BildAir Seas0nPass[512]: [CONNECTED] VID: 0x05ac / PID: 0x1227
Nov 1 15:08:03 BildAir Seas0nPass[512]: status: 1
Nov 1 15:08:03 BildAir Seas0nPass[512]: SHATTERING
Nov 1 15:08:03 BildAir Seas0nPass[512]: shatter_user.ecid: 2645448379852, Device->ecid: 2645448379852
Nov 1 15:08:03 BildAir Seas0nPass[512]: shatter_user.bdid: 16, Device->bdid: 16
Nov 1 15:08:03 BildAir Seas0nPass[512]: shatter_user.cpid: 35120, Device->cpid: 35120
Nov 1 15:08:03 BildAir Seas0nPass[512]: shatter status: 2
Nov 1 15:08:04 BildAir Seas0nPass[512]: [.] Exploit data successfully sent!
Nov 1 15:08:05 BildAir Seas0nPass[512]: [.] SHA1 registers pointed to 0x0.
Nov 1 15:08:06 BildAir Seas0nPass[512]: device_detached!
Nov 1 15:08:06 BildAir Seas0nPass[512]: SHATTERING
Nov 1 15:08:06 BildAir Seas0nPass[512]: in detach iterator
Nov 1 15:08:06 BildAir Seas0nPass[512]: shatter_user.ecid: 2645448379852, Device->ecid: 2645448379852
Nov 1 15:08:06 BildAir Seas0nPass[512]: shatter_user.bdid: 16, Device->bdid: 16
Nov 1 15:08:06 BildAir Seas0nPass[512]: shatter_user.cpid: 35120, Device->cpid: 35120
Nov 1 15:08:06 BildAir Seas0nPass[512]: shatter status: 3
Nov 1 15:08:06 BildAir Seas0nPass[512]: device with location id: 639631360 detached
Nov 1 15:08:06 BildAir Seas0nPass[512]: [.] PASS_2
Nov 1 15:08:06 BildAir Seas0nPass[512]: closing interface
Nov 1 15:08:06 BildAir Seas0nPass[512]: USBDeviceClose
Nov 1 15:08:06 BildAir Seas0nPass[512]: [DISCONNECTED]
Nov 1 15:08:06 BildAir Seas0nPass[512]: [.] preparing oversize…
Nov 1 15:08:06 BildAir Seas0nPass[512]: Device->enabled == false
Nov 1 15:08:06 BildAir Seas0nPass[512]: failed to reset USB counters.
Nov 1 15:08:06 BildAir Seas0nPass[512]: <tetherKitAppDelegate: 0x7f9b68d49c90> tetheredBootReady:
Nov 1 15:08:06 BildAir kernel[0]: 000352.121188 PRT2@26200000: AppleUSBHostPort::resetGated: retrying enumeration in 100 ms
Nov 1 15:08:08 BildAir kernel[0]: 000353.450365 PRT2@26200000: AppleUSBHostPort::resetGated: retrying enumeration in 200 ms
Nov 1 15:08:09 BildAir kernel[0]: 000355.000680 PRT2@26200000: AppleUSBHostPort::resetGated: retrying enumeration in 400 ms
Anybody from Firecore have anything to add?
Try another usb.
or another port.
i tried 3 different usb cable, 2 usb port…
i try on a another computer, the same problem.
Would be great to have some support on this issue!!!
Very frustrating!
I can resolve it.
  1. Connect USB to ATV2 and Restored 5.3 .ipsw on iTunes
  2. Restar your Mac
  3. Connect USB to ATV2 (iTunes Will open automatic), be sure to close iTunes
  4. Connect Power Cable to ATV2, be sure to close iTunes (this tip helps fix the problem - Failed to reset USB Counters)
  5. Runs Seas0nPass last Version and start de Jbk
Works… :slight_smile:
I can resolve it.
  2. Restar your Mac
Works… Smile
Okay so Ive tried the method of powering device during jailbreak, after restore to 5.3 ipsw but still get the same USB counter issue. Ive rebooted, quit itunes and done this process 3 times on a mac running el capitain. No luck so far. Any others having this issue? Any tips…?
Congratulation howarddesign.
I have the same problem and error-massage.
Ideas ??
Nothing to do.
Hey, FireCore… Anybody home??
I’ve tried all suggested methods as well as all past methods and to no avail. Still running 5.3 but would really appreciate the upgrade.
Same here, failed to reset USB counters during 6.2.1 Jailbreak procedure (after enable DFU modus)
Anyone else managed to get past this issue succesfully?Any tips??
AppleTV2, attempted jailbreak from 5.3, on OS X El Capitain.
Same error, every time…where is the love!??
