Failed to open input stream in demuxing stream
Hey @james
I started getting the “Failed to open input stream in demuxing stream” error right after scanning my library on a new device.
I know this issue is usually related to some kind of Google Drive temporary ban or rate limit, but what’s strange is that if I use another app (same movie, same account, same Google Drive), it works perfectly fine. No error at all.
It seems like Infuse might be handling something differently when accessing the files. Could this be fixed in a future update, or is there any workaround I could try?
Thanks!
