„Fade-IN“ and „Fade-OUT“
Hey James :wink:
Please add the soft Fade-Out (Fade-In is already done, but Fade-Out is still missing) ??
And please set the Start-Transition to BLACK (instead of GREY)…
This Video show you this in Detail:
And hide the „Spinning Wheel“ (tvOS) :slight_smile:
=> Could you please add an Option to hide the „Spinning Wheel“ on Start and End of the Videoplayback?
On very fast Gigabit-Ethernet-Connections, there is no Spinning Wheel needed…
(Only on very slow Networks, to give the User a visual feedback, that something is still Loading…)
If the Network is very fast (Gigabit-Ethernet), then the Spinning Wheel is anyway just visible for 1 Second, and there is an Option needed to completely hide it to give an perfect smooth Transition between the Video and the Infuse tvOS GUI :slight_smile:
Look here for a PDF:
Great idea ?
This would be really cool ?
It seems a Fade-In is already there, but where is the Fade-Out?
