Extras/Bonus Content Artwork
Is there a way to customize the artwork/icon for Extras? I have some family videos with Extra content and I’ve tried adding a photo, as well as changing the video’s poster frame.
Thank you!
The documented way is a per-file local override: place an image with the exact same name next to the video file (for example Inception-2010.mkv with Inception-2010.jpg), and Infuse uses it as the poster. For an extra named something like FamilyTrip-short.mp4 the matching image would be FamilyTrip-short.jpg. Two settings matter for this to work: “Prefer Local Artwork” in Infuse under Settings, Metadata & Artwork tells Infuse to use those local images, and since you also tried changing the poster frame inside the video, the “Prefer Embedded Artwork” option in the same settings section controls whether embedded artwork is used. Both options are described in Firecore’s support articles on overriding artwork and on the settings overview.
If the image still does not show after that, a reload of the metadata for that file (long-press, Reload Metadata) is the usual refresh step mentioned in the docs.
I’m not talking about a movie’s poster or fanart. I’m asking about EXTRAS/BONUS content. How do I change that poster?
Ah, understood - you mean the bonus clips, not the movie itself. Firecore’s Metadata 101 describes how extras get attached (filename with -behindthescenes/-deleted/etc., or an extras folder inside the movie folder), but the docs do not call out artwork for extras specifically. Since every extra is its own video file, the same override from the Overriding Artwork guide should apply: put a JPG with the exact same filename next to the extra file and enable Prefer Local Artwork under Settings > Metadata & Artwork, then use Edit > Reload Metadata on the item. I have not verified that extras pick it up the same way, so treat that as an educated guess. If the clips come from Emby/Jellyfin/Plex instead of local files, the artwork is managed on the server side and has to be changed there.
I got an update – it’s currently not possible.
