Extrafanart and Extrathumbs Folders
Hello
Can we have the option for Infuse to egnore these folders? When using both Kodi and Infuse, Kodi adds these extra folders, unfortunately Invuse then shows a folder with the movie name instead of just the movie.
These folders will be ignored in recent versions of Infuse.
Can you provide a bit more info on what you’re seeing?
Hello
When looking at TV Shows I can see all the episodes but if there is a folder called Extrafanart or Extrathumbs in the same folder as the episodes then that is also visible. It is only seen in TV Shows. If those folders are present in movies then they seem to be ignored. This seems to be the problem when running Kodi along side Infuse from the same NAS.
